How to add and delete media clips in the Media Library of Corel VideoStudio Pro
0 users found this article helpful
Adding and deleting media clips in the Library:
To organize the media clips in the Library so you can access assets for your projects with ease and speed. You can also import a Library to restore media files and other library information.
To add media clips to the Library:
  1. Click Add to create a new library folder where you want to store yourmedia clips.
Note: You can create custom folders to separate your personal clipsfrom sample clips and manage your assets more efficiently or tokeep all clips that belong to a project in a single folder.
  1. Click Import Media Files to locate your files.
  2. Select the files you want to import.
  3. Click Open.
  4. Click Browse to open the File Explorer where you can drag and drop files to the Library or Timeline.
To delete media clips from the Library
  1. In the Library, select a clip and press [Delete Delete].Or, right-click the clip in the Library and click Delete. Note: While the clips are referenced in the Library, they actuallyremain in their original location, so when you delete a clip from the Library, only the Library instance is deleted. You can still access the actual file in the location where it is stored.
  1. When prompted, confirm that you want to delete the thumbnailfrom the Library.
To automatically locate and restore the link of the files in your library
  1. Click File > Relink. A message appears that notifies you about the number of clips that are successfully relinked.
Note: If the links to some clips are not restored, you can restorethem manually by browsing for the corresponding file on yourcomputer.
To export a library
  1. Click Settings > Library Manager > Export library and specify afolder location where you want to save your Library.
  2. Click OK.
Note: It is recommended that you back up your Library to avoid losing important library information and media clips. This action creates a backup of the virtual media files information of your current library in a directory you specify.
To import a Library
  1. Click on Settings > Library Manager > Import Library and find thefolder path of the directory you want to import.
  2. Click OK.
Note: To reset your Library to the default settings, select Settings > Library Manager > Reset Library.
Keywords: how, vsp, x4, x5, import, bring, insert, open, add, remove, delete, restore, library, media, photo, video, audio, clips
Was this article helpful?
