CorelDRAW Technical Suite 2019: How To Manually Uninstall
0 users found this article helpful
Here is the procedure to uninstall CDTS 2019, including all locations where files/components may remain after a failed uninstall attempt
  1. Restart your operating system to ensure everything is properly closed and complete any pending Windows updates successfully.
  2. In Windows Control Panel, click Uninstall a program.
  3. Remove these programs in this particular order, if installed.
    1. Corel Graphics - Windows Shell Extension
    2. Ghostscript GPL 8.64
    3. CorelDRAW Technical Suite 2019 ensuring that Remove User Files is checked.
      If the option for ‘Remove User Files’ is checked, application user files such as workspaces, application preferences will be removed.
    4. XVL Player / XVL Player Pro
    5. XVL Studio 3D Corel Edition (may already be removed when successfully uninstalling the Suite)
  4. It is also recommended that you visually inspect the installation and user folders, as well as the user location in the registry (if possible) for files and entries that may have been left behind. If they have not been removed during the uninstall process, they may need to be manually deleted.
Below are the locations which you should look after uninstalling CorelDRAW Technical Suite 2019. Look specifically for entries related to 2019; if you have earlier versions, other entries will exist.
Installed folder location (default):
64-bit version on 64-bit OS, 32-bit version on 32-bit OS:
C:\Program Files\Corel
32-bit version on 64-bit OS:
C:\Program Files (x86)\Corel
User File location:
C:\Users\<accountname>\AppData\Roaming\Corel\CorelDRAW Technical Suite 2019
C:\Users\<accountname>\AppData\Roaming\Corel\Databases\Assets V1.0
C:\Users\<accountname>\AppData\Roaming\Corel\Databases\V3.1
C:\Users\<accountname>\AppData\Roaming\Corel\Messages\540111125_******
C:\Users\<accountname>\AppData\Roaming\Corel\Messages\540111136_******
C:\Users\<accountname>\AppData\Roaming\Corel\Messages\540227267_******
C:\Users\<accountname>\Documents\Corel
Public File location:
C:\Users\Public\Documents\Corel
All Users File location: (C:\ProgramData or C:\Users\All Users)
C:\Users\All Users\Corel\CorelDRAW Technical Suite 2019
C:\Users\All Users\Corel\Downloads
C:\Users\All Users\Corel\Messages\540111125_******
C:\Users\All Users\Corel\Messages\540111136_******
C:\Users\All Users\Corel\Messages\540221068_******
C:\Users\All Users\Corel\Messages\540227267_******
Registry locations:  You may want to back up the registry before using regedit.
HKEY_CURRENT_USER\SOFTWARE\Corel\Corel DESIGNER\21.0
HKEY_LOCAL_MACHINE\SOFTWARE\Corel (32-bit version on 32-bit OS, 64-bit version on 64-bit OS)
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Corel (32-bit version on 64-bit OS)
Installer .msi components: C:\Windows\Installer folder
After the above steps, reboot the system and try to reinstall again.
Was this article helpful?
