What is AES Encryption?
2 users found this article helpful
WinZip applications support 128- and 256-bit key AES encryption, which provides much greater cryptographic security than the traditional Zip 2.0 encryption method used in earlier versions of WinZip.
WinZip 12.0 introduced customizable password policies to configure password complexity requirements when using encryption in WinZip. Setting a minimum password length and a required mixture of letters, numbers, and/or characters are user defined options (see Password Policy). The options that can be specified are upper case letters, lower case letters, numerals, and symbols.
WinZip's advanced encryption (FIPS-197 certified) uses the Rijndael cryptographic algorithm which, in 2001, was specified by the National Institute of Standards and Technology (NIST) in Federal Information Processing Standards (FIPS) Publication 197 as the Advanced Encryption Standard (AES).
Encrypt Dialogue
When properly implemented as a key component of an overall security protocol, AES permits a very high degree of cryptographic security, yet is fast and efficient in operation.
WinZip's AES encryption is just as easy to use as traditional Zip 2.0 encryption: all you have to do is select the encryption method and specify your password.
In addition to AES encryption technology, WinZip provides a number of usability enhancements that make it easier for you to use encryption. Most noticeably, you can easily encrypt the contents of an existing Zip file. If you are using version 14 or later, WinZip will recognize Intel-based computers with built-in AES encryption and use the available hardware support to make encryption operations two to three times faster.
If you have any questions about this information, please submit a Technical Support ticket.
Related Articles:
Password Policy for Encryption
How strong is WinZip's encryption?
How do you encrypt files in a Zip file with WinZip?
What can I do if I forget the encryption password for my Zip file?
Was this article helpful?
