How do I compress and email files with WinZip?
10 users found this article helpful
WinZip products provide several ways for you to quickly and easily send Zip files as email attachments or share them as a link:
WinZip Courier
How to use WinZip Courier to zip attachments
Using Cloud Services with Courier to send large files
WinZip
How to compress and attach files or folders from an open folder window
How to compress attachments while composing messages
How to directly mail a Zip file open in WinZip
Using Cloud Services with WinZip to share files
WinZip Courier provides an easy way to compress attachments when you press Send or immediately as you attach your files. Courier requires a supported version of Outlook or a supported webmail service used with a supported internet browser in order to work. With WinZip Courier, you will save time preparing and sending emails with attachments because you can:
The WinZip Courier Quick Start Guide gives an overview of how to use WinZip Courier.
With WinZip Courier you can send Zip files that are larger than the file size allowed by your email provider. You will first need to create an account with at least one cloud service. Then you can either let Courier choose to use a cloud service whenever your Zip file will exceed the configured size limit or you can choose to use the Attach Large File button. This latter option allows you to avoid the possibility of an error that can occur if you use Microsoft Exchange and have a file attachment size limit.
Using WinZip Courier with cloud services you can:
With WinZip Courier, uploading to a cloud service will work in the background allowing you to continue to work with other email messages, rather than having to wait until message sending completes.
To compress files or folders and attach them to a new email message from an open folder window, simply right-click on the files or folders and choose Zip and E-Mail from the WinZip submenu on the context menu. WinZip will compress the selected items in a temporary Zip file, create a new email message, and attach the Zip file to it. You can then address and mail the message as you normally would. WinZip will automatically delete the temporary Zip file when it is no longer needed.
You can use the technique described here to compress attachments while composing messages using Outlook or other programs that allow you to attach files using the standard Windows File Open dialog box. This technique does not require a MAPI-compatible email program.
  1. Open the dialog box you normally use to attach files
  2. Locate the file you wish to attach
  3. Right click the file and choose Add to filename.zip from the WinZip context menu
  4. Click the new Zip file to select it
  5. Click Open or Insert to attach the Zip file
If your default email program is MAPI-compatible or you have WinZip configured to use its built-in emailer, you can mail the currently open Zip file without leaving WinZip. To do so, click Email in the Actions pane. If your email program is not running, it will be started automatically. XP users should choose Send ToMail Recipient (Zip and E-Mail) from the File menu.
With WinZip, you can share Zip files as a link to a cloud service. You will first need to create an account with at least one cloud service and configure WinZip to use it. Then, whenever you use one of WinZip's email features, such as Zip and E-mail, if the Zip file reaches the configured size threshold, it will be uploaded to your cloud service account and a link to your Zip file will be placed into the message being sent.
If you have WinZip configured to use its built-in emailer, you will have the option to click the button saying Attached so that it then reads as Linked. This allows you to optionally share Zip files that are smaller than the configured size threshold. Also, if you are configured to use this built-in emailer, you can right click any self-extracting Zip file and choose Email filename.exe from the WinZip context menu. Your self-extracting Zip file will then be uploaded to your cloud service account when your email message is sent and the recipient of your message will be able to download it.
Starting with WinZip 22.5, for those users on Windows 10 there is also an option to share using Windows Charms. You must have a supported cloud service configured in WinZip. Then, when you click Windows Charms, your file will be uploaded to your cloud service, a link will be copied to the clipboard, and you will be given the choice through a dialog to choose a Windows Charm (app) to use for sharing your file. These include the built-in Mail app, copying the link, Microsoft OneNote, and more. Some of the selections may require you to install the appropriate app from the Microsoft Store.
If you have any questions about this information, please submit a Technical Support ticket.
Related Articles:
Does the person receiving my message need WinZip Courier or WinZip?
WinZip Backup jobs
How to use the E-mail tab in WinZip Options
Working with Cloud Service Accounts
Using Cloud Services with WinZip for Sharing
Email Sharing with WinZip
Email Sharing with WinZip Courier
The Attach Large File Feature
Was this article helpful?
