This article explains the process on how to remove manually VideoStudio 12.0 on your computer:
1.Download and install the attached Microsoft Windows Clean Up utility. This will remove all registry keys associated with the VideoStudio 12.0 install process:
2.Run the Windows Clean Up utility; Click Start >> Programs >> Windows Install Clean Up. Highlight VideoStudio 12.0 from the list of products. Click Remove. Click Exit when done.
If an error occurs after clicking the remove button, just click Ok to ignore and exit the utility.
3.Delete the following folders/directories:
- C:\Program Files\Corel\Corel VideoStudio 12\
- On Windows XP:
C:\Documents and Settings\[username username]\application data\Ulead Systems\Corel VideoStudio\12.0 - On Windows Vista:
C:\Users\[username username]\AppData\Roaming\Ulead Systems\Corel VideoStudio\12.0
- On Windows XP:
4.Go to C:\Program Files\InstallShield Installation Information\ and delete the {F0FDF9C9-1DDC-401F-B638-36F1CAE8A875} folder.
5.Go to Start >> Run and then type: regedit
6.Hit "OK" to launch Regedit window.
7.Go to "My Computer\HKEY_CURRENT_USER\Software\Ulead Systems\Corel VideoStudio"; delete the folder "12.0"
8.Go to "My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Corel VideoStudio"; delete the folder "12.0"
9.Close the Regedit.
10.Clean up temporary files and Recycle Bin by launching the Disk Cleanup from Start menu >> Programs >> Accessories >> System Tools >> Disk Cleanup.
Was this article helpful?
