WinDVD Pro 12: How to manually remove WinDVD Pro 12 from Windows
4 users found this article helpful
Below you will find the instructions to manually remove WinDVD Pro 12 onto your system.
These steps are to be performed if you are unable to uninstall WinDVD Pro 12 in Windows using Programs and Features, Uninstall a program, or if you are unable to reinstall and the program is not present.
 Note: Before you start, ensure you have the necessary information such as link/DVD and serial number to reinstall.
Part One - Windows Explorer
Part Two - Windows Registry
NOTE: Be sure once entering, to click File> Export> And save a copy of your registry before continuing. Be also sure that the Export Range on the bottom left, is set to All before you press save.
NOTE – To drill down to the necessary locations, simply double click on each heading to expanding the list
         157288B0A249ccc4FBDB243117A08CEA
         C8C078918A197b9409DEF0B777A7FDC3
         CE8F2BC7F91Bf2245AACC86466B2C9E8
         D4E1B06120FC4c24F8FCEE2044A04936
         F1FFD0138E43EA545A4C425987887DA9
         F23BEA7B2C3FC0F43A44141ECBC9C8ED
         F942F94A19C0F79468FD2B85E5E8677B
        _{19870C8C-91A8-49b7-90ED-0F7B777ADF3C}
         {0B882751-942A-4ccc-BFBD-4213710AC8AE}
         {160B1E4D-CF02-42c4-8FCF-EE02440A9463}
        {7CB2F8EC-B19F-422f-A5CA-8C46662B9C8E}
       {A49F249F-0C91-497F-86DF-B2585E8E76B7}
       {B7AEB32F-F3C2-4F0C-A344-41E1BC9C8CDE}
Part Three - You are ready to reinstall
Was this article helpful?
