If opening a .cdt file crashes the application, it may contain a linked bitmap that has been renamed or deleted.
Try changing the file extention from .cdt to .cdr, then open the file in CorelDRAW. If the file contained a linked bitmap that has been renamed or deleted you will get a warning stating that the bitmap could not be found. At this point you can resave the file as a .cdt without the missing bitmap.
Comments
0 comments
Article is closed for comments.
