Cannot Install: SETUP or INSTALL program filename contains folder information
11 users found this article helpful
The WinZip Unzip and Install feature is a simple, "implied extract" process for software applications distributed in WinZip files. This feature is available when WinZip detects the presence of a file named SETUP.EXE or INSTALL.EXE.
When invoked on a WinZip file containing a recognized setup program, the Unzip and Install feature creates a temporary subfolder in the user's
%TMP% folder extracts all the files in the archive to that temporary location, including any stored path information, then runs the setup program from that temporary location. If the SETUP or INSTALL file is itself inside a folder in the WinZip file, WinZip will display the error message below:
How to fix?
WinZip displays this message because the Unzip and Install feature can only run a setup program directly from the root of the temporary subfolder it created. It is unusual for software installation WinZip files to contain a setup program with folder information. No version of WinZip supports using Unzip and Install when this is encountered. As instructed in the message, Unzip and Try should be used at this point.
Was this article helpful?
