Compression method used for this file is 95
1 users found this article helpful
If you did the following:
  1. Began unzipping a Zip file
  2. A WinZip dialog displayed stating that problems were encountered
  3. You clicked Yes to see details
  4. The View Last Output dialog showed the compression method used is 95
This would indicate that XZ compression was used on one or more files in the Zip file. This is a compression method first made available in WinZip 18. Earlier versions of WinZip will not be able to extract files compressed with this method.
You are welcome to download, install, and evaluate the current version of WinZip. You can then use this evaluation version to extract the contents of your Zip file. An alternative would be to contact the person who sent the Zip file to you and ask him or her to recreate the Zip file using a compression method that is compatible with your version of WinZip.
If you have any questions about this information, please submit a Technical Support ticket.
Related Articles:
What is a Zipx File?
Default compression - What it is, how to change it
What is the difference between "Legacy" and "Best method" compression?
Using Jpeg compression in WinZip
Was this article helpful?
