WinZip Backup jobs
1 users found this article helpful
WinZip Backup jobs automate the process of creating and updating Zip files. They are great for your repetitive zipping tasks, such as:
WinZip jobs let you specify what files you want zipped, how you want them zipped, where the resulting Zip files should go, and more. Please see the various sections of this article below for more.
Pre-configured Data Backup Jobs
To quickly zip important data, WinZip provides a set of pre-configured data backup jobs. These are found easily in the WinZip Backup tab and they will locate and Zip data files from any or all of these locations on your computer:
The Job Wizard
The easy-to-use Job Wizard helps you to create and/or edit your own jobs. It guides you, in a few quick steps, through the process of specifying exactly how your backup job should work.
Using the Job Wizard you can specify:
Scheduling WinZip Backup jobs
You can schedule jobs to run:
Scheduling jobs is easy with the WinZip Job Wizard. Just choose daily, weekly, or monthly; specify schedule details if applicable; type in your user name and password; and click OK. Since the Schedule Job dialog is a custom interface to the Windows Task Scheduler, your username and password will be required to save your scheduled job.
Job Schedule Dialogue
Note: The WinZip Job Wizard will prefill User name in a fashion similar to Computer name\user name. If the computer is a member of a domain, you will need to change the user name to be similar to Domain\user name.
Save a copy to the Cloud
If you need to save a copy of your backup to a cloud service, click the Save to button in step 6 of the Job Wizard. If you click the Save a copy to button, the Configure Saving to Cloud dialog will open. You can then check the box to Save the Zip file to a cloud service and click the button to select which service to use. If you are not currently logged in to the cloud service you select, you will be prompted to do so. You can also choose options to overwrite an existing Zip file, if one is in the chosen location, and/or to move the Zip file created on your local drive into the Recycle Bin after a copy of it has been uploaded.
WinZip Job Cloud dialog
In older WinZip versions, FTP was a separate service and so required its own configuration dialog. In the current version of WinZip and other recent versions, FTP is treated as another cloud service. The FTP sign in window that will open when you choose FTP for the Save to location does include most of the same distinctive settings as the earlier service.
WinZip FTP Sign In dialog
Since FTP is provided with your other cloud services, you can use it outside of WinZip Jobs as well. For example, from an open Zip file you can click FileSave As and choose FTP from the listed cloud services if you wish. This is also an option you can choose while creating and saving a Zip file.
Email Notification
You can send the Zip files created by WinZip Backup jobs to an email recipient as files or as a cloud link. You can also configure your backup job to send you a notification when it has finished. To do this, click Email in step 6 of the Job Wizard, select your desired notifications, specify the email account information, choose from the list of options, and WinZip does the rest. Whenever your job runs, the Job Wizard will email the resulting Zip and/or log file automatically.
WinZip Job Configure E-Mail dialog
If you click the Email button in Job Wizard before you have configured an email account (in WinZip), the Set Up EMail Account dialog will display first. The Email tab in the WinZip Options dialog can be used at any time to add an email account or make changes to ones you have previously configured.
If you have any questions about this information, please submit a Technical Support ticket.
Related Articles:
What is a Data Backup?
Backup types and strategy examples
Restoring Data from Backups
Cloud Services and Backups
Was this article helpful?
