Studio capture error Video Device Not Found
1 users found this article helpful
In Studio 10, 11 and 12 the full error message looks like this:
Studio has the ability to capture from many different capture devices. The message above is giving the basic troubleshooting steps on 2 broad categories of capture devices, Digital and Analog.
Examples of digital devices are DV, Digital 8 or HDV camcorders. If you are trying to capture from this type of device, please go to Case 1, below.
Examples of analog devices are 8mm or Hi-8 camcorders, DVD players or VCRs. If you are trying to capture from one of these devices, then please go to Case 2, below.
Case 1: If you are capturing from a Digital source (DV, Digital 8, HDV) follow these steps:
1. Studio source has to be set to 1394.
a. In Studio, click on the Setup pulldown menu, then click on Capture Source
b. In the box marked Capture Devices, make sure that the Video and Audio are set to DV camcorder - Pinnacle 1394. Then click OK. Studio is not set to capture using the 1394 port
NOTE: if there is no option for DV Camcorder, then Windows is not loading the 1394 Host controller driver. Skip to Step 3 below to troubleshoot the driver in Device Manager. Once the driver is loaded properly, then restart with Step 1 again.
2. Check the DV, Digital 8 or HDV camcorder for ALL of the following:
NOTE: Do not connect a DV camcorder via the USB port since Windows will not see the camcorder and load the camcorder driver.
3. Device Manager. Check Device Manager to verify that both the 1394 controller and the Digital camcorder drivers are loaded.
When your 1394 controller and Digital Camcorder are installed properly, they will look like this in Device Manager:
NOTE: When the camcorder is turned on and off the camcorder driver will load and unload. You should see your cursor turn to an hourglass as the device is detected and Windows loads the driver. Also, Windows (XP and Vista) will typically give a "Found New Hardware" or messages when the camcorder is turned on as the device is detected.
NOTE: If your 1394 port is on a separate card (not part of your motherboard), then try placing the 1394 card in another PCI slot. Use the following instructions to move the card:
  1. shut down the computer.
  2. move the 1394 card into another PCI slot. If you don't have an available slot, then swap places with another PCI card.
  3. restart the computer. The hardware wizard should detect the new hardware automatically.
  4. follow any on screen instructions to finish loading the driver if any appear.
  5. check Device Manager to see if the driver for the 1394 card loaded properly.
  6. If it has, check to see if Studio
4. AMCAPTURE (also sometimes called AMCAP for short). If both the 1394 controller and DV camcorder drivers are listed properly in Device Manager and Studio will still not capture from the device, then try to capture using AmCapture. AmCapture is a small, basic, capture utility from Microsoft that can capture from DV devices.
If you can't get AmCapture to capture from the DV device, then there is something wrong with either the 1394 driver or the DV driver, which are part of Windows XP. Please contact either Microsoft or your computer vendor for assistance. If you are familiar with the XP Repair procedure, some customer's have success running it to fix 1394 driver problems.
If AmCapture does work, then we recommend you uninstall and reinstall Studio. Click here to see the uninstall/reinstall procedure for Studio 12. You can also capture your video in AmCapture and then import the video into Studio for editing as a workaround.
Case 2: If you are capturing from an Analog source (8mm or Hi-8 camcorder, VCR, etc) follow these steps to set the correct Capture Source in Studio:
b. In the box marked Capture Devices, you may notice that the Video and Audio are set to DV camcorder - Pinnacle 1394.
c. To capture from analog, select the correct device for Video and Audio. The screen below shows the Pinnacle Dazzle DVC 100 being selected as the capture device. On some analog capture devices there is no audio input, so you have to (1) set the Audio Capture device in Studio to your sound card's Line In and (2) cable the analog audio source (VCR or analog camcorder) to the Line in on the sound card.
NOTE : If on step 4 above, no Analog device is listed, then:
  1. you may not have an analog capture device in the computer and you will have to purchase one or..
  2. you do have the hardware but it's device driver is not being recognized.
    • If the hardware is from a 3rd party company, please contact their support department to reinstall their driver.
    • If the hardware is from Pinnacle, click on the link above to continue troubleshooting the problem.
Was this article helpful?
