How to use fast or slow motion in Studio
0 users found this article helpful
Fast or slow motion in Studio is accomplished through the use of the Speed plugin. The Speed effect allows you to set the speed of any video clip over a continuous range from 10 to 500 percent of normal, in either forward or reverse motion.
If the clip contains audio, that too is sped up or slowed down. The option of maintaining the original pitch lets you avoid the sudden introduction of cartoon voices into the soundtrack.
To access the Speed effect, open either the video or audio toolbox. To access the Speed effect from the video toolbox, select the Standard RTFX category, then select the Speed effect. To access the Speed effect from the Audio toolbox, select the Standard Audio Effects category, then select the Speed effect.
When the Speed effect is accessed from the video toolbox, there is an option to adjust the speed % as well as options for Reverse and Smooth Motion.
When the Speed effect is accessed from the audio toolbox, there is an option to adjust the speed % as well as an option to Hold Pitch.
Was this article helpful?
