Installing Toast Updates
0 users found this article helpful
  1. Double-click on the Toast Update file you have downloaded from Roxio web site. The Toast 8 Update v8.x window appears on your desktop.
  2. If you wish to keep the current version on your computer as well as the newer version, rename the current version in the Applications folder using the Finder before proceeding.
  3. Drag the Toast Titanium and/or other applications from the Toast Update window into theToast Titanium folder on your hard disk (probably located inside the Applications folder). The message saying "A newer item named 'Toast 8 Titanium' already exists in this location. Do you want to replace it with the older one you are moving?" will pop up. This will install the update and not the previous version already installed on your computer. Click Replace (orYes) to install the update.
  4. In the Toast Titanium folder on your hard disk, double-click the Toast Titanium application to launch Toast. Follow the on-screen instructions.
Was this article helpful?
