Users should always try to remove Roxio Creator 2011/2012 from Control Panel in Windows.
Windows 7 and Vista: Start button > Control Panel > Programs and Features
Windows XP: Start > Control Panel > Add/Remove Programs
The solutions below should only be tried if you encounter installation issues after you have removed Roxio Creator using the uninstall options in Windows:
The Creator 2011 System Cleaner should only be used as a last resort and will work with Creator 2011, Creator 2012, Creator 2012 Pro, Creator NXT, & Creator NXT Pro. Please read the instructions carefully to ensure the Creator 2011 System Cleaner works properly.
To use the System Cleaner:
- Stop any Roxio installation or program processes.
- Extract the Creator 2011 installer:
- If you downloaded your program, you will need to extract the installer .exe file to a new folder. You may need to download a program to extract the installer - such as WinZip (trial) or WinRar. If the .exe extracting capability is installed, right-clicking on the .exe file will give you a menu option to extract it. Be sure to extract the .exe to a new folder on your hard drive.
- If your installer is on a disc, right-click on the installation disc and select Explore to open it. Then copy all the files to a new folder on your hard drive.
Ê
- Download and install the Creator 2011 System Cleaner here. After downloading, unzip the C2011_CleanSystem.bat file to the folder where the installer files are extracted to in Step 2. It should be in the same folder as the Creator 2011 setup.exe file.
![](https://kb.corel.com/Attachments/kcs-181468/Create.jpg)
- Double-click C2011_CleanSystem.bat to begin the process.
- When the Remove Roxio Creator 2011/2012/NXT window appears, click on the Install button to continue.
- The process should take a few minutes to complete.
- Restart your computer.
Was this article helpful?
