ParticleShop: How to manually remove ParticleShop from Windows
1 users found this article helpful
Below you will find the instructions to manually remove ParticleShop onto your system.
These steps are to be performed if you are unable to uninstall ParticleShop in Windows using Programs and Features, Uninstall a program, or if you are unable to reinstall and the program is not present.
Note: Before you start, ensure you have the necessary information such as link and serial number to reinstall.
Part One - Windows Explorer
 1) Open File Explorer
2) Navigate to C:\Windows\Installer
3) Change your view to "details"
4) Right click on the sorting tool bar, and select Title
5) Click on Title to sort the list alphabetically
6) Scroll through the list, regarding the items under Title, and delete all Particleshop,entries
7) Change the location then to C:\Program Files\Corel
8) Delete the folder Particleshop
Part Two - Windows Registry
NOTE: Be sure once entering, to click File> Export> And save a copy of your registry before continuing. Be also sure that the Export Range on the bottom left, is set to All before you press save.
1) On your keyboard, hold the Windows Key down and tap the letter R
2) In the run box that appears, type in regedit and press enter
NOTE – To drill down to the necessary locations, simply double click on each heading to expanding the list
3) Navigate to the following locations and delete the keys specified:
HKEY_CLASSES_ROOT\Installer\Products\118BDB76B383B2D478E02FD752112F00
HKEY_CLASSES_ROOT\Installer\Products\640422F6461E87B48976A34E4972D192
HKEY_CLASSES_ROOT\Installer\Products\8F384F4D1F17F754BAB1136C51926B85
HKEY_CLASSES_ROOT\Installer\Products\C7657E803B4765945B575FB5CF7CC713
HKEY_CLASSES_ROOT\Installer\Products\D1AA99E9CD1FD2449B9DD83DEE25A99E
HKEY_CURRENT_USER\SOFTWARE\Corel\ParticleShop
HKEY_LOCAL_MACHINE\SOFTWARE\Corel\ParticleShop
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\118BDB76B383B2D478E02FD752112F00
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\640422F6461E87B48976A34E4972D192
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8F384F4D1F17F754BAB1136C51926B85
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\C7657E803B4765945B575FB5CF7CC713
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\D1AA99E9CD1FD2449B9DD83DEE25A99E
4) Close the registry
5) Restart the computer
Part Three - You are ready to reinstall
Was this article helpful?
