How to install the Corel PaintShop Photo Project Creator Separately
1 users found this article helpful
If you need to install PaintShop Photo Project Creator separately, then you can follow the steps below.
NOTE: Just follow the steps if PaintShop Photo Project Creator was not installed after installing the PaintShop Photo Pro X3.
ESD
  1. If you ordered the download version of Paintshop Photo Pro X3, you should be able to see a separate download link of PaintShop Photo Project Creator from the order email that was sent to you. If you no longer have the order email, you can access an online version of your receipt by following the steps from this link:    How Can I Re-Download My Order?
  2. After downloading the installer, just run the installation process and follow the on screen steps that will appear.
  3. When asked for a serial number, use the same serial number that you use to install the PaintShop Photo Pro X3.
  4. Once the installation process is complete, just click on FINISH to complete the installation process.
Box/Disc installer
  1. Insert the disc and wait until the AUTORUN screen appears.
  2. Click on the INSTALL PAINTSHOP PHOTO PROJECT CREATOR, then just follow the on-screen instruction that will appear.
  3. When asked for a serial number, just provide the same serial number that you use to install the PaintShop Photo Pro X3.
  4. Once the installation is done, just click on the FINISH to complete the process.
Was this article helpful?
