Marking misspelled words and grammatical errors as you type in WordPerfect
8 users found this article helpful
You can use Spell-As-You-Go to automatically check spelling in a document. Spell-As-You-Go underlines misspelled words in red.
You can also use Grammar-As-You-Go to automatically correct grammatical errors. Grammar-As-You-Gounderlines grammatical errors in blue.
Prompt-As-You-Go replaces misspelled words, grammatical errors, and synonyms. The Prompt-As-You-Golist box displays suggestions as you type. A color coding system identifies the type of error encountered:
In this example, the Prompt-As-You-Go list box displays suggestions for a misspelled word.
To check for misspelled words automatically
Note
A red underline displays below each misspelled word.
Spell-As-You-Go is enabled if a bullet displays next to it. If Grammar-As- You-Go is enabled, Spell-As-You-Go is also enabled even though there is no bullet next to Spell-As-You-Go
Tip:
You can disable the automatic checking of spelling errors by clicking Tools Proofread  Off.
You can replace the misspelled word with a new word by right-clicking the misspelled word and clicking a word from the menu.
To check for grammatical errors automatically
Note:
A blue underline displays below each grammar error.
If Grammar-As-You-Go is enabled, Spell-As-You-Go is also enabled even though there is no bullet next toSpell-As-You-Go.
Tip:
You can disable the automatic checking of grammatical errors by clicking Tools > Proofread Off
To enable prompts for correcting spelling and grammar and using synonyms
1.   Click Tools Proofread Prompt-As-You-Go
       A check mark next to the Prompt-As-You-Go command indicates that Prompt-As-You-Go is enabled.
2.   Click a word or phrase in your document.
3.   Choose the replacement text from the Prompt-As-You-Go list box on the property bar.
Note:
If the text in the Prompt-As-You-Go box is red, the word may be misspelled. If the text is blue, there may be a grammar or usage error. If the text is black, you can choose a synonym to replace the word. If the box is blank, there are no suggestions for the word.
Was this article helpful?
