Customizing the Property Bar in WordPerfect
3 users found this article helpful
The property bar displays different controls depending on the type of object that is selected. Buttons can be added to the property bar. The appearance of property bar buttons can be changed so that they display with text only, pictures only, or with both pictures and text. The pictures on the Property bar can be edited to be used for a property bar button. It is even possible to change the location of the Property bar.
And if necessary, the original settings of the property bar can be restored at any time.
To change the location of the property bar
1. Click Tools Settings.
2. Click Customize.
3. In the Customize settings dialog box, select the Property bars tab.
4. Choose a property bar from the Available property bars list.
5. Click Options.
6. In the Property bar location area, select one of the following buttons:
Left docks the property bar to the left side of the document window
Right docks the property bar to the right side of the document window
Top docks the property bar at the top of the document window
Bottom docks the property bar at the bottom of the document window
Palette creates a floating property bar that can be moved anywhere along the screen
Additional information:
To add a button to the property bar
2. Click Customize.
4. Choose a property bar from the Available Property bars list.
5. Click Edit.
6. In the Property bar editor dialog box, select a category from the Feature categories list box.
7. Choose a feature from the Features list.
8. Click Add button.
To change the appearance of a property bar button
2. Click Customize.
3. In the Customize settings dialog box, click the Property bars tab.
5. Click Options.
6. In the Button appearance area, enable one of the following options:
Text displays text only on the property bar button
Picture displays pictures only on the property bar button
Picture and text displays pictures and text on the property bar button
To change the picture on a property bar button
2. Click Customize.
5. Click Edit.
6. On the property bar, right-click a property bar button, and click Customize.
7. In the Customize button dialog box, click Edit in the Image area.
8. In the Image editor dialog box, modify any of the settings.
To restore the original settings to the property bar
2. Click Customize.
5. Click Reset
Keywords: how to, information, 000015421, tips,
Was this article helpful?
