VideoStudio X4/X5: Keyboard Shortcut Keys in Corel VideoStudio Pro
12 users found this article helpful
Menu command shortcuts
Ctrl + NCreate a new project
Ctrl + OOpen a project
Ctrl + SSave a project
Alt + EnterProject Properties
F6Preferences
Ctrl + ZUndo
Ctrl + YRedo
Ctrl + CCopy
Ctrl + VPaste
DelDelete
F1Help
Step Panel shortcuts
Alt + CGo to Capture Step
Alt + EGo to Edit Step
Alt + FGo to Effect in the Gallery list
Alt + OGo to Media in the Gallery list
Alt + TGo to Title in the Gallery list
Alt + SGo to Share Step
UpGo to the previous step
DownGo to the next step
Navigation Panel shortcuts
F3Set mark-in
F4Set mark-out
Ctrl + PPlay/Pause
SpacePlay/Pause
Shift + Play buttonPlay the currently selected clip
HomeReturn to the starting segment or cue
Ctrl + HHome
EndMove to the end segment or cue
Ctrl + EEnd
BPrevious frame
FNext frame
Ctrl + RRepeat
Ctrl + LSystem Volume
Ctrl + ISplit Video
TabToggle between the Trim Handles and Scrubber.
EnterWhen the left Trim Handle is active, pressing [Tab Tab] or [Enter Enter] switches to the right handle.
LeftIf you pressed [Tab Tab] or [Enter Enter] to make the Trim Handles or Scrubber active, use the Left-arrow key to move to the previous frame.
RightIf you pressed [Tab Tab] or [Enter Enter] to make the Trim Handles or Scrubber active, use the Right-arrow key to move to the next frame.
ESCIf you pressed [Tab Tab] or [Enter Enter] to activate and toggle between the Trim Handles and Scrubber, you can press [Esc Esc] to deactivate the Trim Handles / Scrubber.
Timeline shortcuts
Ctrl + ASelect all clips on the Timeline. Single title: Select all characters in the on-screen edit mode.
Ctrl + XSingle title: Cut selected characters in the on-screen edit mode.
Shift + ClickSelect multiple clips in the same track. (To select multiple clips in the Library, [Shift Shift] + [Click Click] or [Ctrl Ctrl] +[Click Click] the clips.)
LeftSelect the previous clip on the Timeline.
RightSelect the next clip on the Timeline.
+/-Zoom in/out.
Ctrl + RightScroll forward.
Ctrl + LeftScroll backward.
Ctrl + Up / Page upScroll up.
Ctrl + Down / Page DownScroll down.
HomeMove to the start of the Timeline
EndMove to the end of the Timeline
Ctrl + HThe previous segment.
Ctrl + EThe next segment.
Multi-trim Video shortcuts
DelDelete
F3Set mark-in
F4Set mark-out
F5Go backward in the clip
F6Go forward in the clip
EscCancel
Was this article helpful?
