VideoStudio X10: How to disable advertisements / Popups
0 users found this article helpful
In order to disable the advertisements coming from VideoStudio X10, it is recommended to change the frequency of the messages to "Do not show me tray message for this application.   Here are the steps to follow:
1. Launch VideoStudio X10
2. Click on Help
3. Select Message Preferences
It will look similar to this:
4. Press the down arrow key and select "Do not show me tray message fro this application"  and click OK.
This option will prevent advertisements from displaying within VideoStudio X10
If the recommended solution does not work for you, I suggest to disable or delete the CorelUpdateHelper
1. Using the search box, to the right of the START icon from Windows, type: Task Scheduler and press Enter
2. Click on Task scheduler Library
3. Locate CorelUpdateHelperTask, right-click and select Disable or Delete
4. Locate CorelUpdateHelper TaskCore, right-click and select Disable or Delete
5. Click the X at the top right to close the dialog box
If all of the above solution does not solve the issue, please contact Corel Support Services
Was this article helpful?
