NOTE: Before removing or installing a program, patch or update, please log in as administrator. The only way to get full administrator access on Vista/Windows 7 is to turn off the User Account Control and have the program installer "Run as Administrator".
Vista: http://windows.microsoft.com/en-US/windows-vista/Turn-User-Account-Control-on-or-off
Windows 7: http://windows.microsoft.com/en-US/Windows7/Turn-User-Account-Control-on-or-off
Solution A: Control Panel (recommended)
- Go to Start ▸ Control Panel and select Add or Remove Programs (XP)/Programs and Features (Vista/Windows 7)
- Select MotionStudio 3D from the list
- Highlight and select the Remove or Uninstall button
- Restart the computer.
- Re-install MotionStudio 3D by re-downloading the installer from the Order Confirmation e-mail or by logging in to your corel.com account. If installing from a CD version, then insert the DVD.
Solution B: Manually uninstalling (intermediate to advanced users)
- This step will requires entering into the Windows registry. This is recommended for more advanced users who are comfortable with editing the Windows registry.
- First, remove the Program folder:
- Windows Vista and 7
- START ▸Computer ▸Local Disk C ▸Program Files (x86) ▸Corel
- Delete the Folder named: Corel MotionStudio 3D 1.0
- Windows XP
- START ▸My Computer ▸Local Disk C ▸Program Files ▸Corel
- Next, delete the temporary files,
- Windows Vista/7
- Hold down the Windows key + R key until you get the Run box
- Type appdata and click the OK button
- Left double click on the Roaming folder
- Left double click on the Ulead Systems folder
- Search for and delete the Corel MotionStudio 3D 1.0 folder
- Windows XP
- You will need to show your hidden files and folders before proceeding. Click HERE to see instructions on how to make hidden folders visible.
- From the START menu, open the Control Panel
- Open Folder Options
- Select the View tab
- Under Hidden files and folders select show hidden files and folders
- Click OK
- Type %appdata% and then click on OK
- Click on the Folder Up button
- Find and open the Local Settings folder
- Open the Application Data Folder
- Open the Ulead Systems folder
- Delete the MotionStudio 3D folder
- Locate the Documents folder in Windows and locate the Corel MotionStudio 3D folder.
- Delete this folder.
- Windows Vista/7
- Windows Registry
- START▸Accessories▸Run
- Type: regedit
- Click OK
- It is necessary and highly recommended to back up the Windows registry before continuing in case any mistakes are made in the registry, it can be replaced by the saved capy.
- Click File▸Export
- Save File to desktop
- Give the backed up file a name
- Click Save and then wait for the file to save
Windows Registry MotionStudio 3D key Removal Step #1
Expand HKEY_CURRENT_USER folder
Locate and expand the Software folder
Locate the Corel folder and expand it
Locate the Corel Motion Studio 3D folder and delete it
Locate the Ulead Systems folder and expand it
Close the HKEY_CURRENT_USER folder
Windows Registry MotionStudio 3D key Removal Step #2
Expand the HKEY_LOCAL_MACHINE folder
Expand the Software folder
(if using Windows 64bit systems)
Locate and expand the Wow6432Node folder
Locate and expand the Ulead Systems folder
Locate the Corel MotionStudio 3D folder and delete it
Close the Wow6432Node folder
(if using Windows 32bit systems)
Locate and expand the Corel folder
Windows Registry MotionStudio 3D key Removal Step #3 Go to each of the following entry and delete:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\0E2A777799F3A4F4B81F05C7404CC56D
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\4B33BEBB48F4E06449141A18400FC186
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\6A2159CC7FB85DF4CBFC506FCF1D9916
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\9B5077776F6E4B44AB1A847EA0EC7104
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\C633005CAEE6FB946841CCFF215E26F8
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall_{CC9512A6-8BF7-4FD5-BCCF-05F6FCD19961}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{777705B9-E6F6-44B4-BAA1-48E70ACE1740}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{7777A2E0-3F99-4F4A-8BF1-507C04C45CD6}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{BBEB33B4-4F84-460E-9441-A18104F01C68}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{C500336C-6EEA-49BF-8614-CCFF12E5628F}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{CC9512A6-8BF7-4FD5-BCCF-05F6FCD19961}
Restart your computer.
Re-install Corel MotionStudio 3D 1.0.
Was this article helpful?
