Painter: How to change language in Painter
9 users found this article helpful
By default, Painter will install in English. If your Region settings are set to your specific native language and you still show English in the program, try the following Steps:
  1. Click start and type in regedit to open the Registry Editor
Locate and left click File in the upper left hand corner of the Registry Editor, then click on Export
Choose the Desktop as the location to save the file in, and name the file "regbackup"
Also ensure that under the Export Range section there is a dot beside All
Click "Save
 Your registry should now be backed up to a file named "regbackup.reg" on your desktop.
  1. Navigate to HKEY_CURRENT_USER\Software\Corel\Painter\14.0
NOTE - the folder which you choose determines the version you are running
13.0 = Painter X3
14.0 = Painter 2015
15.0 = Painter 2016
16.0 = Painter 2017
18.0 = Painter 2018
  1. Right click on the right hand pane New > String Value, type in UILanguage
  2. Double click on the new key and enter the value of the key to be "EN" if you want to switch to German later you would enter in "DE", French "FR" etc..
  3. Launch Painter
Was this article helpful?
