In CorelDRAW, how do I break apart text to move letters closer?
13 users found this article helpful
To break apart text, select the text and go to Object > Break Text [Font Name] Apart. This will break the words apart. If you repeat this command, it will then break the letters apart.
However, this is not necessary if you are only looking to change the position of words or characters. Instead, simply select the text with the Shape tool and you will have control nodes that you can use to move the characters. You will also have control handles at each end.
You can also find the CorelDRAW Q&A video here on the Discovery Center, where we answer more questions submitted by CorelDRAW users
Was this article helpful?
