Interactive Fit Text to Path Tool
7 users found this article helpful
The applications and features described in this tutorial require CorelDRAW Graphics Suite X3 or newer to be installed.
Since CorelDRAW X3, it's easier than ever before to attach text to a path with precisiona common effect used in creating signs and logos. The interactive Fit Text to Path tool lets users simply select text, move the pointer along a path, and click to set the text's position. Users can also easily control the text's offset distance from the path.
In addition, users can scale the text after it has been placed on a path by simply selecting both the text and the path and dragging one of the handles.
Using the interactive Fit Text to Path tool
  1. Click the Freehandtool, and draw a curved line to use as a path.
  2. Click the Texttool, click anywhere in the drawing window, and type.
  3. Click Text > Fit Text To Path.
    The pointer changes to the Fit Text to Pathpointer. As you move the pointer along the path, a preview of where the text will be fitted is displayed.
  4. Move the pointer along the path, and click to fit the text.
    With a closed path, the text is centered along the path. With an open path, the text flows from the point of insertion.
  5. On the property bar, adjust the value in the Distance From Path list box.
  6. On the property bar, adjust the value in the Horizontal Offsetlist box.
  7. In the Mirror Text area on the property bar, use the Mirror Horizontalor Mirror Verticalbuttons to choose the text's orientation.
Was this article helpful?
