Activation of CorelDraw Graphics Suite X4 Written Instructions
68 users found this article helpful
 This article contains two sets of instructions:
I already have the product installed on my computer -
I do not currently have the productinstalled on my computer -
Please follow the instructions for your current scenario.
If you already have the product installed on your computer, you may use your serial/purchase key to activate the program.
  1. Open the product and then close it.
  2. You will get a dialog with a button titled "Activate now!"
  3. Click on Activate now!. The program should automatically be activated in a few seconds.
  4. You will get a confirmation asking if you would like to Save or Print your activation information. Choose your desired option.
  1. Disconnect the computer from the internet (with dial up accounts, just disconnect the dial up connection. With broadband accounts, disable the network connection option by doing the following:
    a. Go to Start | Control Panel.
    b. Double click on Network connections (if in Category view, click on Network and Internet Connections, and then on Network connections on the following screen).
    c. Right click on the Local Area Connection icon and choose Disable.
If you have any problems with the above procedure, an alternate option is to physically disconnect the Network Interface Cable from either the back of the computer or thehub that it is connected to.
  1. Launch and close product again
  2. Click the Already Purchased? button. Enter your serial number.
  3. Click on Phone Corel.
  4. You will be offered an Installation Code and your Key with a blank Activation Code field.
  5. Contact Technical Support - Please note that directly phoning technical support is no longer available, you must use the on-line Ask a Question form.
  6. Provide Technical Support with the Installation Code and Key and you will be provided with an Activation Code that can be used to unlock your product.
I do not currently have the product installed on my computer -
If you do not already have the product installed on your computer, you will need to download the program prior to activating it. There will be two different places you may download from:
  1. You will be directed to an Order Confirmation page with a link that says Click to Download just after your order has been completed.
  2. You will besent an Order Confirmation Email with a link that says Click to Download.
Download Instructions:
  1. Click on the Click to Download link on either your Order Confirmation Page or in your Order Confirmation Email.
  2. Make sure to keep an eye out for any pop-up blockers that may be triggered by your browser or internet security software.
  3. You will be offered a File download dialog. Choose to Save the file.
  4. Save the file to a place you know where to find it such as your Desktop.
  5. Once the file has been downloaded, double click the file's icon to initialize the program's install.
  6. Follow the install wizard to install the program. You will be prompted to enter your serial number.
  7. Use the Serial Number provided on either your Order Confirmation Page or in your Order Confirmation Email.
  8. Open the program and then close it. Follow the instructions provided above under I already have the product installed on my computer - to activate the program.
Was this article helpful?
