Â
Quick start
This section introduces some of the basic tasks that you can accomplish in Corel® AfterShot™ Pro. If you're looking for a quick way to start working with the application, take a few minutes to go through the steps below. The steps include handy shortcuts and tips that help you work quickly.
There are three main steps:
- 1. Open your photos in Corel AfterShot Pro.
- 2. Select and edit one or more photos.
- 3. Output your edited photos individually or as a batch.
Before you begin, see Corel AfterShot Pro work space for a quick overview of the workspace.
Step one: Open your photos
To get you started quickly, we're going to work directly from the folders on your computer. After you're familiar with the application, you can choose to build a Library by importing photos into Corel AfterShot Pro. When you're ready for more information, see Understanding the Library.
To navigate to your photos
- In Corel AfterShot Pro, click the File System tab, and navigate to your folder in the Directory View.
- When you click a folder, the photos from the folder are displayed as thumbnails in the Thumbnail panel.
Â
Step two: Selecting and editing photos
To view and adjust images, you need to select them. The 'Thumbnail 'panel displays thumbnails of the photos that are in the active folder. When you select a thumbnail, the Preview panel displays a larger view of the photo. When you edit a photo, the original file (master file) is never altered — edit information is saved separately and what you see onscreen is a master version, a preview that shows your edits. You can edit the entire photo or a selected area of the photo. When you are finished editing a photo, you can simply move on to the next photo, or you can save your changes as a new version. This means that you capture the edits as a variation of the original file. The version can be viewed as a thumbnail or in the Preview panel. It can also be output.
To preview and select photos
- 1. In the Browse panel, click the File System tab.
- 2. Navigate to the folder you want. The Thumbnail panel displays the photos that are in the folder.
- 3. Click a thumbnail to display it in the Preview panel.
Before you start editing, you can choose between viewing the edits directly on the master version of your file, or creating a new version for editing by pressing Insert or by right-clicking the thumbnail and choosing Version > New Version from Defaults.
Â
Note: The last image you select is called the active image. While in Multi-Image View mode, metadata changes, adjustments, and other edits apply only to the active image.
To edit a photo
1. In the Browse panel, navigate to the folder you want.
2. Click a thumbnail to display it in the Preview panel. 3. Experiment by trying any of the editing actions in the following table.
Tip: There are some handy ways to undo actions. Here are a few
Â
you can try:
- To undo one action at a time, press Ctrl + Z or Command-Z.
- To reset a Tools panel slider to its original setting, double-click the slider name.
- To clear all the changes that you've made to a photo, right-click the thumbnail, and choose Settings > Apply Default Settings from the context menu.
To show your edits on a new version
- In the 'Thumbnail panel, right-click or Control-click an edited photo (master version), and from the context menu, choose Version >'New Version from Current.
Note: You can confirm that a photo has been edited by looking for the Edit icon in the upper-right corner of the thumbnail. Corel Af terShot 6 Pro Us er Guide
A new thumbnail appears next to the thumbnail of the master version. By default, versions use the following naming convention: original file name + version number (_v2, _v3, ...).
Â
Â
You can now return to the master version and edit it in a new way and create another version. To start from the original settings, you can clear the edits made to the master version by right-clicking or Control-clicking the thumbnail, and choosing 'Settings > Apply 'Default Settings from the context menu.
Tip: Whether you choose to create a new version before or after editing a master version depends on your workflow. For example, if you know that you want to make several versions from the outset, you can create a version before you start editing, so you can always see how the original master file looks. If you want to quickly fix a photo, you can simply edit the master version—you can create other versions later if you want. The non-destructive nature of editing in Corel AfterShot Pro gives you maximum flexibility.
Â
For more information about editing photos, see Editing photos.
'Step three: Outputting photos for sharing and 'print.
After you organize and edit your photos, you can share your work by outputting your photos. Outputting lets you save your photos to a standard file format so that you can share your work on the Web, via email, or use your files in other applications. You can also output your files to print. There are a number of standard output choices, called batches, that let you output quickly, but you can also create a custom batch. For example, you can choose file type, quality, color space, and image size. You can also set a naming convention to rename the files when they are output and you can apply presets. For more information about outputting, see outputting images.
To get you started quickly, let's use standard batches to save to JPEG and print a couple of 5 x 7 inch photos.
To output to a full-sized JPEG
1. In the Thumbnail panel, select one or more photos that you want to output.
2. Do one of the following:
- In the Browse panel, click the Output tab, and in the Batch Output section, drag the thumbnails to JPEG Full Size.
- Press F (shortcut key assigned to JPEG Full Size batch)
3. In the Select a Destination dialog box, choose a folder where the files will be saved.
After you select a destination folder, files are saved automatically to that folder for the rest of the session. You can change the destination and access other output settings by double-clicking a batch name in the Batch Output or Printing section.
Â
To print to a standard print size
1. In the Thumbnail panel, select two photos that you want to print.
2. In the Browse panel, click the Output tab, and in the Printing section, drag the thumbnails to a batch name, such as 5x7 Qty.2.
3. Double-click the batch name to preview the print job in the Print Settings dialog box.
4. In the Print Layout section, enable the Scale crop or Scale reduce option (matches the photos to the selected print ratio) and preview the results.
5. Choose your printer from the drop-down list in the bottom leftcorner.
6. Click Print.
Moving on
Now that you have been introduced to the basics, here are some additional topics that will provide you with more detailed information:
- Understanding the Library
- Managing your Library
- Editing photos
- Organizing, k eywords, and metadata
- Outputting images
Â
Was this article helpful?
