Error 1935 during installation of your Corel Product
0 users found this article helpful
This may happen, if the Windows Operating System has an erroneous installation of the .Net Framework. Thus, repairing of said Microsoft .NET Framework installation is a known solution for this issue.
To do this, follow these steps:
1. Click Start menu | Control Panel | select Programs and Features or Add/Remove Programs.
2. Under the Currently installed programs list, highlight on Microsoft .NET Framework, and then click Change/Remove.
3. Click Repair, and then click Next.
Repeat this process for other versions in chronological order, if these exists in the list.
Once done, restart your system in Safe mode and see if you can install your Corel software.
Refer to the following Knowledgebase article for information in starting Windows system in Safe mode.
How to perform an installation in Safe Mode
If issue still persists, use the Repair tool from the following link in Microsoft to fix the .Net Framework:
http://support.microsoft.com/kb/2698555
Was this article helpful?
