How to remove Temp files from Windows to resolve multiple software and system issues
43 users found this article helpful
Excessive amounts of Temp files can cause many known issues with Corel products as well as other software running on Windows. Cleaning out the temp directory on a monthly basis should help the following:
It is very easy to clean up temp files, simply complete the following steps:
  1. Click on the Windows Start menu at the bottom left side of your screen
  2. Type into the search box: %temp% (For Windows XP type:%temp% in the RUN command window)
  3. Hit Enter and the Temp directory will open
  4. Hit Ctrl+A on the keyboard to Select All
  5. Hit the Delete key and then press OK or hit Enter to the message asking if you are sure you wish to delete
  6. Skip all files that cannot be deleted (there will usually be about 3 to 5 temp files in use by windows at any given time which cannot be deleted)
  7. Close out of the temp directory
Note *The proceedure may have to be repeated or files deleted in batches when using Windows XP due to its limitations when deleting mass amounts of files*
Keywords: temp files, cleanup, temporary, installation
Was this article helpful?
