Roxio: Easy VHS to DVD Plus (Windows) - How to export recorded videos to a different format
22 users found this article helpful
Your Roxio Easy VHS to DVD software not only allows you to burn captured VHS videos to DVD, it can also convert those captured videos to other video formats and saved to your hard drive, to be played on your computer, or uploaded for streaming or sharing over the Internet.
Exporting your recordings
Once you are done recording and trimming your video, you can click on the "Export" tab, located at the top area of the user interface, or the "Next" button at the bottom right-corner.
Export tab and Next button
This will bring you to the Export workspace, where you can choose the different format settings to be used for converting your video.
The Device Profile Selector
Your first step in exporting your video is to select the device profile. As you will be converting your captured video to a different format (and not burning it to DVD), select "File" from the device profile selector window.
Device profile selector
The Save File Destination
After selecting your device profile, you will need to set its save destination. This is the folder location where the converted video will be exported to.
Select the saved file location
Clicking on the ellipsis button will bring up the Browse window. Here you can navigate to and select a pre-existing folder, or you can make a new one.
Browse for a folder or make a new one
Export Quality
Use the Quality slider to adjust video quality.
The quality slider
Moving the slider to the right improves the quality and increases the file size. Advanced Settings affect the Quality setting, so recheck Quality if you make other setting changes.
Advanced Settings
This is where you choose all the different format settings for your video.
Advanced settings
Click on the plus (+) button to expand window and see all the available settings to choose from.
Advanced Settings window
Below is a rundown of the different options available in the Advanced Settings area.
Exporting your video
Once you have selected your compression method, the video frame rate, resolution, and data rate, you can then proceed to execute the convert and export process by clicking on the "Export" button at the bottom right-hand corner of the application window.
The export button
As mentioned before, do keep in mind the higher the values you select for the export settings, although they make for a very good quality video, the bigger its file size will be as well. So it is best to strike a good balance between quality and file size.
Was this article helpful?
