Installing AfterShot Pro 3 on Fedora 35
7 users found this article helpful
Symptoms
AfterShot Pro 3 does not initially install on Fedora 35
Cause
Dependency issues
Resolution
This article assumes basic familiarity with Fedora Linux and using a terminal command prompt.
  1. Install AfterShot without dependencies:
    1. Open a terminal window in Fedora.
    2. Enter the following command to install AfterShot:
      sudo rpm -ivh --nodeps https://dwnld.aftershotpro.com/updates/v3/AfterShotPro3.rpm
  2. The RPM will install some libraries which may conflict with current Fedora libraries, so we move the provided ones out of the way. Continuing in the terminal:
    cd /opt/AfterShot3\(64-bit\)/lib/
    sudo mkdir ./backup/
    sudo mv ./* ./backup/
    sudo mv ./backup/libbibblesdk.so.5 ./
  3. Install a version of compat-openssl10
    sudo dnf copr enable dioni21/compat-openssl10
    sudo dnf -y install compat-openssl10
  4. Install required dependencies
    sudo dnf install \
          libglvnd-glx \
          libICE libSM \
          libXcomposite \
          libXext \
          libXi \
          libsecret \
          ocl-icd \
          libgpg-error \
          qt \
          qt5-designer \
          qt5-qtmultimedia \
          qt5-qtbase \
          qt5-qtbase-gui \
          qt5-qtsvg \
          qt5-qtwebkit \
          qtkeychain-qt5
  5. The qt.conf file is not required and can cause issues. We'll rename that:
    cd /opt/AfterShot3\(64-bit\)/bin/
    sudo mv ./qt.conf ./qt.conf.backup
  6. Run AfterShot. You will be prompted for a library folder and a settings folder. It's safe to just click OK here.
  7. Enjoy!
Many thanks to the good folk over at: https://www.ctrl.blog/entry/how-to-aftershot-pro-fedora.html
Was this article helpful?
