WordPerfect: Manual feed (envelope, cards, etc) prints an extra page
0 users found this article helpful
Symptoms:
When printing from the manual feed tray on a printer capable of duplexing (two-sided printing), the printer feeds an extra blank sheet after one-page jobs, and sometimes after multi-page jobs.
Cause:
Two-sided printing is enabled in the printer driver, WordPerfect, or both.
Resolutions:
There are multiple ways to address this depending on the workflow needed. Options one and two are best if one rarely prints two-sided documents.  These options turn off two-sided printing by default.
Option three shows how to turn off two-sided printing on a per-envelope basis, while leaving it on as the default for all other WordPerfect documents.
1) Set the Print Driver to default to single sided printing:
  1. Click on your Windows menu and search for Printers & Scanners, then open Printers & Scanners.
  2. Click on the printer you would like.
  3. Click Manage.
  4. Click Printing Preferences.
  5. Change the 2-Sided Printing to 1-Sided for that printer.
2) Set WordPerfect to default to single sided printing:
  1. Open WordPerfect. If WordPerfect was open when you completed the steps above, save your work, then close and reopen WordPerfect.
  2. Type a few letters into WordPerfect
  3. Click File, Print
  4. Click the Layout Tab
  5. Under Two-Sided Printing, choose "Off"
  6. Click the Main tab at the top
  7. Click Edit Settings
  8. Ensure that "Layout" has a checkmark beside it on white background.
    1. If it does not, click on the checkbox until it is a black checkmark on a white background.
  9. Ensure the "Name for current settigns" field at the top reads "[Application Default]"
  10. Click "Save". If "Save" is greyed out, just close the edit settings window.
NOTE:
You can still print double-sided by choosing the Layout tab when you print and selecing Book or Tablet.
3) Print individual envelopes single sided:
  1. Open WordPerfect and any documents you're working with.
  2. If you have an address on screen, select it.
  3. Click Format, Envelope...
  4. Edit / correct the addresses and select the envelope size
  5. Click Create New
  6. Click File > Print (or click the print button on the task bar)
  7. Click the Layout tab at the top of the print dialog
  8. Enable Off under "Two-sided printing"
  9. Click Print
Was this article helpful?
