Vector FX Installation Guide, Requirements and Troubleshooting.
5 users found this article helpful
Installation:
  1. Upon completion of your purchase, you will receive an email with details of your order and a download link which will provide you with the installer for Vector FX.
  2. Vector FX will always download and install to your C: drive, so ensure you have adequate space to install Vector FX (~50GB during download/installation, 15GB once installation is completed).
  3. Run the ".exe" file and it will begin to download the application files. Once the installation begins, there will be a serial number window that is auto-populated with a serial. Click "Download Now". Please note that this download may take some time.
  4. Once the files are downloaded, accept the license agreement and then the installation will begin.
  5. After the installation is completed, you will be able to launch the Vector FX as a standalone application.
To use:
  1. Launch Vector FX
  2. Enter Text Prompts describing your desired output and adjust sliders for fine-tuning.
  3. Click Run to initialize the vector generation process.
  4. If you need to hit Stop at any point during the process, the progress bar will be replaced by a message indicating that the model is stopping the generation. Once that message disappears, you can resume by hitting Run again.
  5. Once the application generates all five images you can click Save to save the file in SVG format to your desired location.
  6. You can then open that file in CorelDRAW Graphics Suite or other vector editing software to further tweak and refine the vector as needed, or you can use as-is in your projects.
 Minimum Requirements
Recommended Requirements for faster results (using GPU acceleration)
Supported Languages: English Only
For any technical issues with Vector FX, please contact the developer directly via this support portal - https://go.support.distinctplugins.io/servicedesk/customer/portals
Was this article helpful?
