Publishing to PDF in Corel® WordPerfect Office
0 users found this article helpful
Publishing to PDF in WordPerfect Office
When you need to share files with others, you can publish them to PDF and preserve the typography, images, graphics, color, and formatting of the original file.  In order to view the PDF file, the recipients of the document must have Adobe® Reader, Corel® PDF Fusion, or Corel® WordPerfect Lightning installed on their computers.
The PDF you create can consist of either the entire document or only parts of the document, such as individual to a range of pages.
When you publish a table of contents, index, list, or table of authorities to PDF, each marked heading or subheading is numbered sequentially.  The entries appear in the PDF as bookmarks in the document.
You can also add file information, such as the author's name or keywords, to the PDF file.
WordPerfect lets users publish documents to PDF.
In addition, you can create PDF files that are compatible with different versions of Adobe® Acrobat and with the PDF/A standard, which is defined by the International Organization for Standardization (ISO).  The purpose of the PDF/A standard is to ensure the reliable reproduction of files for long-term preservation.  In other words, the PDF/A files that you create today will be readable for years to come. You can create PDF files that comply with the requirements of either PDF/A-1a or PDF/A-1b.  The difference between PDF/A-1a and PDF/A-1b is that PDF/A-1a allows document tags and font encoding while including all the requirements of PDF/A-1b.  This higher level of compliance lets you search and re-purpose the document content.
You can verify the compliance of a PDF file by creating a log file.  The log file created for a PDF file contains details about what was done to the file to achieve compliance when the file was published.  In addition, the log file lists all limitations and warnings.
Steps on how to publish to PDF
1.   Click File ▸ Publish to PDF.
2.   Choose the drive and folder where you want to save the file.
3.   Type a filename in the File name box.
4.   From the PDF style list box, choose one of the following options:
5.   Click Save.
* If you publish to a PDF/A style, the document fonts are automatically embedded in the file. Some licensed fonts are meant to be viewed only in the original document, however, and you are prohibited from redistributing the font. Therefore, before publishing to the PDF/A style, you must make sure that you can redistribute the fonts. To view the licensing information and embedding restrictions for a font, you can use a tool such as the font properties extension tool that is available for free on the Microsoft Web site.
To publish only parts of a document to PDF
2.   Click Settings.
The Publish to PDF settings dialog box appears.
3.   In the Export range area, enable one of the following options:
* If you enable the Pages option, you can type the numbers of the pages that you want to publish in the Pages box.  You can use a hyphen to indicate a range of pages and a comma to indicate nonconsecutive pages.  For example, typing 1- 5 lets you publish pages 1 to 5, whereas typing 1,5 lets you publish pages 1 and 5.
To add file information to a PDF file
2.   Click Settings.
3.   Perform one or both tasks from the following table.
To
Do the following
Add author information
Type a name in the Author box.
Add keywords
Type keywords in the Keywords box
To change the PDF compatibility settings
2.   Click Settings.
3.   On the General page, choose a compatibility option from the Compatibility list box:
 •  Acrobat 3.0 (PDF 1.2) - creates a PDF file that is compatible with Adobe Acrobat 3.0
 •  Acrobat 4.0 (PDF 1.3) - creates a PDF file that is compatible with Adobe Acrobat 4.0
 •  Acrobat 5.0 (PDF 1.4) - creates a PDF file that is compatible with Adobe Acrobat 5.0.
 •  PDF/A-1a - creates a standardized PDF file that ensures the long-term archiving of the document.  This option allows document tags and font encoding to be preserved.
 •  PDF/A-1b - creates a standardized PDF file that ensures the long-term archiving of the content.  This option does not include the preservation of document tags and font encoding.
* PDFs that have been saved with Acrobat 5.0 can be opened in later versions of Adobe Acrobat.
To generate a log file
2.   Click Settings.
3.   Click the Advanced tab.
4.   Enable the Generated log file check box.
Was this article helpful?
