AfterShot 3 Pro / AfterShot 3: How to reset to factory defaults in Mac OSX
3 users found this article helpful
Symptoms
In some cases, AfterShot's default installation may become corrupt or damaged preventing the application from launching or working properly. This document will restore factory defaults through a two-part process of renaming AfterShot's registry entries and configuration files.
Resolution
To restore the product to its factory defaults, follow the instructions listed below.
First, make sure that AfterShot is closed. This is especially important. If it is open, the reset process will not work as expected.
  1. Close AfterShot
  2. Open the Terminal (Applications > Utilities > Terminal)
  3. Enter the following commands into the terminal.
    1. Note, the second line contains back-quote characters, normally found on the tilde key next to the 1 at the top left:
  4. Commands for AfterShot 3 PRO:
    cd ~/Library/Application\ Support
    mv "AfterShot Pro 3" "AfterShot Pro 3-`date +%Y%m%d-%H%M%S`"
    exit
  5. Commands for AfterShot 3:
    mv "AfterShot 3" "AfterShot 3-`date +%Y%m%d-%H%M%S`"
    exit
  6. Now, run AfterShot Pro 3 or AfterShot 3.  It will ask you where your library folders are but will not re-ask you for your serial number.
Was this article helpful?
